rayms69
automaki
petes68pony
machlarson
Author Topic: 9 inch rearend and yoke questions  (Read 588 times)
Offline JBauer4363
  • Quiet Type
    • Stuff
« on: February, 24, 2010, 05:37:29 PM »
 I really messed up. The 9 inch open rearend thats in my Mustang has been noisy since I put it in and I decided to replace it. I bought a rebuilt one off ebay to replace it and today I got it. I never gave it a thought about the yoke and of course its different than my old rear. The new one has a short yoke and the old one is long. What will I have to do to get the driveshaft to work. Looks like the difference is about an inch.
 What sucks is I bought the new rear because everyone locally that I asked about rebuilding the old one wasnt interested or wanted as much as I payed for the new rear.
How bad is this?
Thanks in advance.
Offline monkeystash
Re: 9 inch rearend and yoke questions
« Reply #1 on: February, 24, 2010, 06:27:03 PM »
I'm not an expert by any means, but I'm pretty sure you can just swap the yokes.  You will need a new crush collar and have to reset the pinion bearing preload.  Here is some info:
http://www.differentials.com/install.html
-Ryan
Offline 66gt350
  • Ah like me sum gunz...
« Reply #2 on: February, 24, 2010, 07:57:36 PM »
That's no problem at all.  When I ordered my new rear, I thought that I had the short yoke, so that's what I got.  When I got it home I needed the long yoke.  The suspension shop ordered the correct one and swapped it.  Just cost me a little extra money, since I had to order 2 yokes.
Anyone need a yoke, installed but never put on the car...
-rob "Ricky Bobby"
Offline JBauer4363
  • Quiet Type
    • Stuff
« Reply #3 on: February, 24, 2010, 08:10:12 PM »
 Ya that would be easy but the shop i bought it from is long distance and the part is heavy. shipping $85 each way plus the instal     :cry
Offline 66gt350
« Reply #4 on: February, 24, 2010, 09:11:44 PM »
Since you have the correct yoke on the old 9", you could use it on the new pumpkin.  Does the new pumpkin have a pinion crush collar or does it have a newer style solid collar?  The new pumpkin I bought (with the wrong yoke) has a solid pinion collar.  When the shop got the new one in, all they had to do is impact off the wrong yoke and install the new one.  So far, I've got about 1000 miles on the rear end with no problems.
Offline buening
« Reply #5 on: February, 25, 2010, 05:21:25 AM »
.....and then there is the old school way of swapping the yokes and torquing the nut down to 100ft-lbs without a new crush collar.  Not that I condone this but may old school guys do this and don't have a problem.   No guarantee that the gears will mesh perfectly as before though.
Custom Motor Mounts
T56 Conversion
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #6 on: February, 25, 2010, 09:55:51 AM »
I think the old school way is assuming you are putting the same parts back together and just changing out the seal.
It might work if the yoke depth below the flange is exactly the same on both yokes.  Might be able to mic it to check and if it comes out the same give it a shot.
Sam
Member number 427
68 Coupe
Offline JBauer4363
  • Quiet Type
    • Stuff
« Reply #7 on: February, 25, 2010, 06:11:20 PM »
Thanks for the help! First of all Ive got to say that I really dont know much if anything about these rearends (thats why I should always ask questions before I act on impulse and buy stuff without thinking about what Im doing). Im hoping there is a fix that I could be able to do. I took some pics so maybe you guys could tell me what Ive got.
Dont know can you tell from these pics?
old yoke:
new yoke:
Any coments are welcomed.
Thanks again.
Offline monkeystash
« Reply #8 on: February, 25, 2010, 06:29:03 PM »
No you cannot tell from the pictures.  The collar is located inside on the pinion gear shaft.
Another option is changing/modifying your current driveshaft.  You could also have one made or maybe find one with the correct length.
Offline 66gt350
« Reply #9 on: February, 25, 2010, 06:39:39 PM »
Unfortunately, monkeystash is right...can't tell without ripping it apart.  If you're unsure about doing it...is there a shop that you could take the pumpkin and long yoke locally to have 'em swap out yokes?  I wouldn't think that a shop would charge you very much for doing that.
Offline JBauer4363
  • Quiet Type
    • Stuff
« Reply #10 on: February, 27, 2010, 03:02:46 AM »
Couldnt get anyone around here to work on my old rearend is why I decided to just get the new one.
This may be a DUMB question but what about the other end of the driveshaft? I mean its only an inch could I get a little longer yoke at the transmission? Do they make one?
Thanks
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #11 on: February, 27, 2010, 05:36:41 AM »
From what I've seen the slip yokes go a long way up into the transmission.  If you're an inch short, just put what you have in there and see how much engagement you still have (trying to be serious and not set up a "that's what she said" line).  What I mean is, if the old driveshaft gave 5 inches of engagement on the output shaft splines, and now you only have 4 inches of overlap/engagement, that may still be enough.  I'm sure there is a spec out there on that, trying to find it now.
Offline 66gt350
« Reply #12 on: February, 27, 2010, 06:25:47 AM »
When I realized that I got the wrong yoke, I asked that question on the other mustang forum.  Ideally, you want the yoke at the tranny to be out 1 inch -- 1.5 inches at the maximum.  With the shorter yoke on the pumpkin, the yoke coming out of the tranny would be about 2 inches, and that is too much.
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #13 on: February, 27, 2010, 06:45:58 AM »
Yeah, now that you mention that, I do remember that from when I was ordering the new driveshaft for my T-5 conversion.  I was thinking in terms of actual spline engagement vice how much of the yoke was showing outside the tailshaft, but effectively that is communicating the same thing.
Offline ZFORCE
  • Triple Uno
  • ZFORCE
« Reply #14 on: February, 27, 2010, 07:16:50 AM »
When you remove the driveshaft from the tranny, you can see the shaft inside of the tranny.  Can't you measure it to see how far inside of the tranny tailshaft it is?  You can then install the new 3rd member and driveshaft engaging it, and then measure how much the the yoke slips into the tailshaft.  This should give you an idea of how much engagement you will have.
Clear as mud?  Don't forget, if you install your new 3rd member with it's present shaft, you lose your pinion snubber.  If you swap yokes on the 3rd member, install your snubber too!
Offline JBauer4363
  • Quiet Type
    • Stuff
« Reply #15 on: February, 28, 2010, 04:50:24 PM »
Good news!! I finally heard from the shop that built the rearend. They use solid spacers instead of crush collar so (they can sell it to a dumbie like me) the yoke can be changed and not mess it up. He said all I have to do is remove the yoke thats on it and put on the one I have. He said just not to "over tighten it"... but didnt say how tight is tight. So I emailed him for that info.
Now I can put this all back together :ecit
Thanks for all the help!
« Last Edit: February, 28, 2010, 04:55:37 PM by JBauer4363 »
Offline monkeystash
« Reply #16 on: February, 28, 2010, 06:23:31 PM »
Sweet, that is good news!
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #17 on: February, 28, 2010, 06:49:33 PM »
Very cool indeed.  I love it when a plan comes together.
Offline 66gt350
« Reply #18 on: February, 28, 2010, 09:13:37 PM »
that's really good news!!!
Offline JBauer4363
  • Quiet Type
    • Stuff
« Reply #19 on: March, 03, 2010, 01:34:35 PM »
Got the yoke switched and while I was at it I spiffed it up a little:
now once it is installed I hope I have no noise.
« Last Edit: March, 03, 2010, 01:36:14 PM by JBauer4363 »
Offline garner67
  • Sunroof Option Expert
    • Garner67 - CarDomain
« Reply #20 on: March, 03, 2010, 01:58:35 PM »
sho is perdy.
congrats on things sorting out!
Mike
Offline sigtauenus
  • stirring the pot
    • Folddownseat.com
« Reply #21 on: March, 03, 2010, 02:49:52 PM »
Looks great.  And with new bearings I bet its nice and tight too.  I love a tight nice looking rear end!!
