Until now, the TV cable adjustment on 1980-93 Ford AOD transmissions required a substantial amount of mechanical knowledge and ability.
I must be a genius! I swapped a HO 5.0L and AOD into a 92 T-Bird, adjusted the TV cable for a firm shift and it was DD for a couple years with no issues. Now my 19 year old son drives it everyday and still no problems!!!
Let's not get carried away here Craig... :craz If it was an EFI swapped with the engine the brackets are already there and basically set from Ford from what I've read. The tricky part is mounting a TV cable to a carb. since you have to use the pressure test port on the AOD and have a fluid gauge that reads 0-5-30 psi to correctly adjust the cable to keep from frying the trans. in a mile possibly. It's not rocket science but does need to be set very close, I've read plenty of posts where people thought they had it 'close enough' and had a fried trans. w/in 50 mi. of driving.Jon
Thanks PJ, I sent Dan an email with my setup and what I'm looking to do with it, then I'll go from there. My biggest fear is that I have no idea if the upgraded clutches, etc. are actually installed in the PATC trans. ...
524 HP and 517 FT-LB.
John, how true this is! Seems everyone makes this out to be the big bear of aod's. I even used the oil pressure gauge off my old ford tractor (nice to have old fords around...lol) to set the pressure for the tv. I then drove it several times and decided to bump the shift points a bit. So I just tightened up the cable a tad and it was just right...no rocket science involved. As long as it's enough, it's good. I think the bad name came from when Ford cheaped out and used a damn plastic grommet at the throttle plate on the efi cars instead of brass like the replacement was. The plastic would get hard and crack and fall out, then the cable had no pressure and the clutches would burn up quickly. So the trusty AOD got a bad name from that. Hell, my wife had a Lincoln Mk7 that had 165K on it and still ran good with no problems. I had replaced the grommet with the brass replacement when I read about it.
