rayms69
automaki
petes68pony
machlarson
Author Topic: AODE swap into classic Mustang-shifter lever  (Read 520 times)
Offline 6t9mach1
  • Quiet Type
« on: February, 02, 2010, 07:30:11 PM »
Alright, which way is the shifter lever suppose to be pointing, up or down, to work with my floor shifter?  I've seen all sorts of conflicting info all over the web about which way it is suppose to be.  Mine is currently pointing down.  Thanks in advance!
~Ryan~
69 Mach 1:  4.11 Detroit Locker, 31-spline axles, manual valve body AODE w/ 9.5" Art Carr converter, 500+ hp solid roller 357w build underway!
Offline gotstang
Re: AODE swap into classic Mustang-shifter lever
« Reply #1 on: February, 02, 2010, 08:01:01 PM »
I think it needs to be facing up. I think my column shift AOD is facing down...or I could have it backwards myself. :lol
Somebody know for sure?
Start a Coupe coup!
'66 Coupe 289 & 3 speed 5.0-AOD, here we come!
My Webpage & Tech pages
Offline 6t9mach1
  • Quiet Type
« Reply #2 on: February, 03, 2010, 04:57:03 AM »
After doing some more reading I think that I need it facing up to use my stock shifter.  It can be used down if you use an aftermarket shifter.  If anyone knows otherwise let me know.  Thanks!
Online cmayna
  • DILLIGARA ?
« Reply #3 on: February, 03, 2010, 07:04:12 AM »
Upright at about a 1 o'clock position.
