rayms69
automaki
petes68pony
machlarson
Author Topic: 66 mustang 8 inch rear axle housing  (Read 475 times)
Offline GT350
  • mustang_aholic there is no cure
    • classic mustangs uk
« on: January, 02, 2010, 04:59:53 AM »
I have a 66 mustang 8 inch rear axle housing available to me ,can i use that in a 67 ?
http://www.classic-mustang.co.uk/index.php
[img width=400 height=29]http://img.photobucket.com/albums/v403/b
Offline AzPete
  • Classic...less
Re: 66 mustang 8 inch rear axle housing
« Reply #1 on: January, 02, 2010, 05:02:46 AM »
I believe it will be 2" narrower than the '67 housing. It would be good depending on what backspacing you want on your wheels. Not sure but I think the mounts are located the same.
USAF/Ret.
7 Previously owned..66-07
Offline AtlantaSteve
« Reply #2 on: January, 02, 2010, 08:29:25 AM »
Yep, Pete's right.  I have a 67 rear axle in my 66...pushed my tires out 1 inch on each side.   Which is fine, because I'm using wheels that normally require 1" adapters on each side.
Steve
Offline guruatbol
  • Grumpy Old Fart!
« Reply #3 on: January, 02, 2010, 09:41:32 AM »
That is good to know.  I want to get a different chunk in the 67, maybe I'll get the 66 and then bury some wider meat under it.....Hum....
