And PS boxes had a quicker ratio??
Then again, what is the disadvantage (if any) of a manual box at high speeds?
I have PS stock 16:1 box but have installed the larger PS pump pulley to lessen the input somewhat, worked pretty good before I took the car down, gave more steering feedback. The larger pulley is similar to installing a valve to lower pressure.
Let me add that you DO NOT want to add power steering to a manual box. You will have the weirdest feeling power steering you have ever felt.
I was under the impression that for 65/66, there is an insignificant difference between the 16:1 manual and power steering box itself, and that they are essentially interchangeable.
Where did you get the larger pulley - online, look for a year/model in junkyard, etc?
I believe I had the C7AZ-D 5" pulley stock and went to the C5AZ-F 5 3/4" pulley. There's a slight difference in the feel.Frank
