jmbyard
rayms69
automaki
petes68pony
Author Topic: Modified T5 bell housing for mechanical clutch setup - pics ahoy!!  (Read 1717 times)
Online cmayna
  • DILLIGARA ?
« on: November, 26, 2009, 03:41:51 PM »
What else did I do today?
Installed the fulcrum bracket and spacer block in Shag's T5 bell housing.   Because the T5 bell housing is a little longer than stock the fulcrum bracket needs to be move forward by the difference. Yes the fulcrum bracket you see is a 65/66.  Though I have a 67+ fulcrum bracket available to use,  the clutch fork and bellhousing that came out of Shag was a 65?  WTF?  And being that the fulcrum clip is 1/4th the cost of a clutch fork, I just got another 65/66 bracket.    I can always swap to a 67/68 for the dimensions are the same.  Only difference is how clutch fork is afixed to the bracket.
Anyhoo....for proper location of the spacer block I attached the throwout bearing, fork assembly to the snout of the tranny.  Fastened the fulcrum/spacer block to the fork and it naturally told me where to mark the bell housing for drilling.
Once established, up onto the drill press went the bell housing and did another test assembly afterwards.  WhooLah!!!
« Last Edit: July, 12, 2010, 05:39:36 AM by cmayna »
Offline Fast68back
Re: Modified T5 bell housing for mechanical clutch setup - pics ahoy!!
« Reply #1 on: November, 26, 2009, 04:42:42 PM »
No thread locker on there
Online cmayna
  • DILLIGARA ?
« Reply #2 on: November, 26, 2009, 06:25:55 PM »
It's only test fitting at this point.  As you can see there's no lock washers or nylon locknuts.  In good time.....
Offline daveSanborn
« Reply #3 on: November, 30, 2009, 05:57:43 AM »
Real clean work Craig.  Thanks for documenting the progress with pictures.  This is a fairly common mod and the pictures will surely help the next guy!
Offline RyanG85
« Reply #4 on: November, 30, 2009, 08:48:15 PM »
Nice work! Is that a kit or something you made yourself? I picked up a T5 for my 65. I was planning on using an adapter plate on the stock bell housing but this looks like a good option.
Online cmayna
  • DILLIGARA ?
« Reply #5 on: December, 01, 2009, 06:27:13 AM »
Ryan, it is a fulcrum kit whis many sell for around $50 which includes the spacer block, fulcrum bracket & fasteners.  Yes one could make the spacer if you want to spend the time, but I was lazy.
Offline pprince
  • 5F09C332634
    • Collector Vehicle Appraisals
« Reply #6 on: December, 01, 2009, 08:00:15 AM »
Don't forget the anti-rattle spring Craig.
1965 Mustang 2+2
prince-cva.ca
Online cmayna
  • DILLIGARA ?
« Reply #7 on: December, 01, 2009, 08:44:56 AM »
As soon as I can find a way to hold my dentures in without rattling, I will then put that spring back in the tranny.
 :craz
Offline Shaun
  • I never go anywhere without my Johnson
    • Street or Track LLC
« Reply #8 on: December, 01, 2009, 11:28:29 AM »
I wouldn't use nylon insert locknuts unless you can verify the temps seen in your bellhousing.  I'd use a high temp red Loctite.
« Last Edit: December, 01, 2009, 12:13:31 PM by cmayna »
Online cmayna
  • DILLIGARA ?
« Reply #9 on: December, 01, 2009, 12:15:17 PM »
That was wierd.  I just accidentally modified your post Shaun instead of quoting it.  My oops. Sorry.
No I have no plans to nylon lock nuts and yes I do have red loctite.
Offline RyanG85
« Reply #10 on: December, 01, 2009, 09:31:13 PM »
Is there a benefit to using the T5 housing with fulcrum kit vs. using an original housing with adapter plate for the T5? I have both housings, just haven't got to this stage yet.
Online cmayna
  • DILLIGARA ?
« Reply #11 on: December, 02, 2009, 06:44:28 AM »
If you have both bells then it's really just a financial decision.  The cost of the adapter vs cost of the fulcrum spacer kit and the time spent modifying the T5 bell.
Shag came with a 164t bell setup so I had no correct size bell to start with, so I bought the T5 for $50 and went from there.
