I have mine installed and have one fill up under my belt since. I still have a small leak, but I think its because that one spot on the bottom wasnt brazed. I have the one I took off if you want I can send it to you Craig, or next time you fly through DFW you can pick it up.
what you need is a little check valve, a flap of metal that only lets gas down, and not back up. maybe a hinged door kind of thing. Probably way harder then your tube idea! :lol
maybe just a tab set back a little from the hole, fuel could drain but it would block the hole directly from the back?!?
As I was catching up on this thread, my thoughts ran along this line also. That will work.....about 1/2" below the drain hole. I will be glad to test it..... :vic
On the 65 I am looking to put a pop open cap. So locking it is out of the question.Mel
I was thinking about this thread and after lurking around here, I think for some purposes you could "Y" the filler neck so that you could fill in the trunk if you want to. I was thinking of mounting my cap on the rear for looks and then putting a filler neck inside the trunk. This would allow me to lock my gas fill and avoid people stealing gas.Mel
I think the deflector will work good. I was also wondering if you were to put the nozzle hole a bit lower than center, if that would give a better shut off control when full......just thoughts......
The way the flap works (I believe) is if you place a nozzle too large in the filler, it won't open the flap. The nozzle is designed to auto shut-off if fuel splashes back into the nozzle. Therefore the flap prevents too much of the wrong fuel from entering the tank. I rent cars every week and have noticed more and more no longer have the flap. I guess this is because there are no longer unleaded nozzles with the larger diameter and not using the flap saves money. I have considered salvage yard hunting to get flapper parts but I don't think the flap is needed.
