When are you going to step up to Google Chrome as your default browser? All the cool kids are doing it.....
I would suspect the starter first
I think it's all that weight in the back seat. Send some over here.Are you saying that it doesn't start right up on a warm start? You say "it acts like it wants to start". Are you saying that when doing a warm crank, it almost fires up but doesn't? Or does it just crank and crank?
If it's starting on a cold crank and it is in the electrical system, the time between cranks (cold cranks) could be allowing the battery to charge back up if it is juiced. If running juices it down, that's symptomatic of an alternator issue. Doesn't necessarily explain why it's not firing after a run. Between you, Derek's problem (now solved) and my issue I have but one question: Does Bush like Mustangs?
I'll bet the starter cable is beginning to get corrosion.
Get you a high torque mini if you haven't already!
