rayms69
automaki
petes68pony
machlarson
Author Topic: Bled Shag's brakes today, thanks kbmwrs & JeffTepper  (Read 390 times)
Offline cmayna
  • DILLIGARA ?
« on: July, 04, 2009, 06:46:55 PM »
Decided to suddenly throw a brake bleeding BBQ party today.  As always my buddies came to my rescue and OMG am I glad
I had their help.
Here I thought I had everything all nice and tight ready for a quick bleed, but nooooooo.   How many leaks could we count 5-6?
We first started on the passenger rear when Jeff yelled "we got a leak up here" (he was manning the MC), while I was under the car and kbmwrs was pumping the pedal.  Fix that leak and then another one, then another one.    I obviously did not properly tighten these 5-6 spots enough.  Had to loosen, tighen, loosen, tighten 3-4 of them.  There was a line leak between the MC and the distribution block.  Distribution block to rear line.  Front driver's banjo bolt with crappy copper washers.  Well, we finally got everything buttoned up, I think.
Spent the rest of the morning and lunch time scarfing down, bbq chicken, flank steak, greek salad & berry pie.
Thanks Jeff & Mike.
Offline Fast68back
Re: Bled Shag's brakes today, thanks kbmwrs & JeffTepper
« Reply #1 on: July, 04, 2009, 06:48:53 PM »
Did you by chance stand around and decide on an engine for that car?
Offline AzPete
  • Classic...less
« Reply #2 on: July, 04, 2009, 06:56:15 PM »
Remember, it is tighten lines and THEN add fluid. We know you set up those leaks just to have something for you "crew" to do.
USAF/Ret.
7 Previously owned..66-07
Offline beach pony
  • Drunkfest Coordinator
« Reply #3 on: July, 04, 2009, 07:03:57 PM »
Thanks Jeff & Mike.
What the hell kinda BBQ is THAT? Since when do we eat Greek Salad at a BBQ. What kinda California BBQ you havin out there. Sheesh.
Did you have ANYTHING that would clog an artery?
Offline lethal289
  • Steel Hoods Rule!
« Reply #4 on: July, 04, 2009, 08:11:45 PM »
Maybe you should have let your daughter or wife do it, since you dont have the strength and all.
Offline Sluggo
  • How you like dat Jake?
    • www.StangFix.com
« Reply #5 on: July, 04, 2009, 08:28:51 PM »
I guess none of you had a camera either?
Offline cmayna
  • DILLIGARA ?
« Reply #6 on: July, 05, 2009, 06:00:56 AM »
Sorry,
Wasn't in the mood to take pics.  Funny the wife also asked about some pics.
Offline Starfury
  • My car HATES me
« Reply #7 on: July, 05, 2009, 06:38:11 AM »
I had the same problem when I converted to disc brakes on my car.  Almost every connection I took apart leaked.
Tad H.
'67 fastback
331 stroker
3sp m/t
Offline JeffTepper
  • Cookie Pimp
« Reply #8 on: July, 05, 2009, 08:51:27 AM »
Even with the leaks, it is a pleasure to work on a pristinely clean car.  I swear it seems that I end up with cleaner hands than when I started!!! :yikes
Anyway, at the end, the fittings were dry and the pedal was hard so I'd say a successful morning of wrenching on Shag.  The BBQ was quite tasty too!!
