TFOB
JTG463
n1kki6
cbowers
Author Topic: New Accelerator rod  (Read 487 times)
Offline Fast68back
New Accelerator rod
« on: February, 20, 2009, 07:09:05 AM »
I had one of those high dollar rods on there and it was a bit short, the pedal was about 4 inches from the floor. Rather than go that route again I ordered the pieces from Speedway motors, I think I have about $15 in this one. Looks pretty sharp.
(the ground strap is not connected because I have the brake line out)
Offline 70_Fastback
  • What to build next...?
  • Hell Bent for Speed
Re: New Accelerator rod
« Reply #1 on: February, 20, 2009, 07:30:50 AM »
I like it.  I wish the 70's came with a rod in lieu of the cable.
Offline AzPete
  • Classic...less
« Reply #2 on: February, 20, 2009, 08:45:29 AM »
Looks nice. Did that same thing on my last '66. Might change out the stock one on this '66 just because...... Love that air cleaner too.
USAF/Ret.
7 Previously owned..66-07
Offline joesgt281
  • Best of Both Worlds...
  • Yak, Yak, Yak
  • Mr. Horsepower
« Reply #3 on: February, 21, 2009, 10:17:45 AM »
nice job.
did the same on mine with a little S-bend to make it all line up.
Offline tarafied1
  • второй craig
  • Russellville KY
    • cardomain site
« Reply #4 on: February, 21, 2009, 06:48:21 PM »
yeah, that looks good. What's the parts list, I'd like to do that too?
Offline Fast68back
« Reply #5 on: February, 21, 2009, 07:49:21 PM »
http://www.speedwaymotors.com/SWEDGED-ALUMINUM-THROTTLE-LINKAGE-10-32-THREAD,3944.html One of these, $7.99
http://www.speedwaymotors.com/PRECISION-LH-MALE-HEIM-3and16-10-32-SHANKandHOLE,7727.html A LH and RH $5.99 ea They also have some standard heims that are only $3.99, not sure what the difference is, figured it was only $4.....
TCP makes/sells basically the same thing through a number of Mustang parts houses and they run about $65
http://www.mustangsunlimited.com/itemdy00.asp?T1=TCPTL2+01
Offline Mustang Mike
    • My 68 from start to almost finished
« Reply #6 on: February, 21, 2009, 07:57:09 PM »
Looks very nice. I built one with 3/8" heym joints and 3/8" all thread rod. I then sleeved it with some copper tubing. Heym joints can be had at NAPA and the rest of the parts were at Lowes.
Mike W.
Offline Fast68back
« Reply #7 on: February, 21, 2009, 08:11:13 PM »
That looks really nice Mike, those heims look pretty beefy. The copper was a nice touch
« Reply #8 on: February, 21, 2009, 10:18:12 PM »
Thanks Rick. I like the fitting on your carb linkage. I found a bronse bushing at Lowes and used a 3/8" bolt for the pin.
